- Replies 5
- Views 2.7k
Mopar1973Man 1 post
cummins 1 post
jonathan1950 1 post
jshmohr 1 post
Fellas, I know this most likely has been talked about and maybe way way back I even started a conversation on it, but my surging is back and i'm looking for thoughts. All summer my truck seemed to work fine with no surging, now that the weather is getting colder , i'm starting to feel it alot. Today it's about 4-5 degrees out and when driving along trying to hold a consistant speed I feel it surging up and down. If I use cruise control it maintains speed with no surging. I'm running 16-19 psi for fuel pressure always , no codes showing in the odometer. I remember last time I had issues I did a reset on the apps, even adjusted the voltage on it, took the IAT sensor out and cleaned it .I think I remember somewhere reading if it doesn't surge with cruise it's not likely the Apps Whatever I did back then it seemed to eventually go away, maybe the weather was warming up, can't remember. Anyway, I was thinking today, i wonder if possibly the IAT sensor is getting weak or bad and now that the colder weather is here it,s not registering accurate and fueling wrong
