Oil pressure / Tach gone crazy
- Replies 13
- Views 4.2k
Rogan 4 posts
dripley 4 posts
txmasterplumber 4 posts
dually 1 post
Man, I need a break... this morning, went out to get ready for work.. start truck for warm up. Leave about 10 min later. About 4 miles from house, look down at gauges and no oil pressure, turn around, go back to house. Check oil, ok, it was a little low (Qt & 1/2) but not enough to show no pressure. It didn't knock or run any different than normal. So I check the gauges out ( key off, push and hold trip odom. button, turn key to on) Everything checks out ok. So I figure its the oil pres. sending switch. Call Autozone... $197 bucks. No way i'm paying that, can get a aftermarket for $100. So, I drove it today, no problems: water temp ok, no engine nock, the check gauges light did come on, of course.Question is, anyone else had this problem, and what did you do to fix, or what should I check?Also, a few weeks ago, running north on I-35W towards Ft. Worth, happen to look down, and Tach shows nothing. About a mile or so, it comes back up. Only time it happened. A few days later, it happened again. Engine didn't sputter, ran fine, tach just crazy or what. Any thoughts?
