- Replies 16
- Views 6.4k
RJC2 6 posts
JOHNFAK 4 posts
dripley 3 posts
Mopar1973Man 2 posts
I have been getting a 0234 code since I bought my truck (in July) and realized that the wastegate was stuck closed, and finally decided to fix it. This is supposed to be a pretty straight forward job. Pull the turbo, free the wastegate and reinstall.Mr. Murphy arrived to help me and I learned about his little law. So, I pulled the turbo and the started working on the wastegate with heat, PB Blaster, and a baby ball peen hammer. I patiently tapped heated and squirted for an hour. Then I think, call Mike Nelson for advice. So Mike advised me to remove the back plate (don't know what it's called) that what-cha-ma-call-it that hooks the turbo to the exhaust, so I can access the wastegate from the rear and heat and apply PB Blaster from both sides. Good advice.After about four more hours of tapping heating and squirting, the weld holding the wastegate actuator arm fatigued, broke and fell off. The shaft is frozen solid. So now I need a new exhaust housing and wastegate for my HY35. Anyone want to guess what I am getting for Christmas?I found a supplier who sells them for $385. Anyone know of a cheaper place? (This a new exhaust housing including the wastegate)FYI, this truck was drove 600 miles during the 18 months before I bought it, thus the really frozen wastegate. Low mileage trucks are nice to find but this is one of the things you have to expect as a possible repair with one.
