Brilliant!!!!
Drilled a hole in my evaporator core while troubleshooting my heater problem. Looks like the dash is coming out the week after christmas
  • Replies 13
  • Views 3k
did you set a distance record for how far a drill can fly or did you maintain your composure?
Nope its a relatively new Dewalt 18V XRP, the heater core and evap core cost less than the drill
It's the new new drill. That thing can start the engines on a 747 and still get thru a safe after loosing the combination.:lol:
Evap Core? CheckHeater Core? Check!Plastex repair adhesive? Check!PAtience? Not so sure about that
Got it back in with a minimum of fuss, will finish connections tommorow
Well it looks like you got a bit of fix to your broken dash and also clean up quite the mess in the HVAC box. Sad you had to do all this because you got wild with a drill... :duh:
One of the mounts was broken on the Heater box. I cut a patch from a junkyard box and used PLASTEX resin system to make the repair
