Had a put an external voltage regulator on my truck because the one in the pcm went bad a long time ago... anyways today the truck started to overcharge, i cought it and pulled over asap. unplugged the external regulator so the truck was just running off the batteries got about half way home and the thing died going down the road. Pulled over, checked my raptor pump and it was putting pressure to the filter housing just fine... changed filter, it was not that bad and usually they do not just make the truck die, but changed it just in case. Then it started up and drove home fine. After about 10mins of being home went to move the truck started then died right away. Started it up again and let it run for about 20mins and it did just fine. Then went to move it again tonight and started ran for about 10mins in the driveway then died. Went to start it, died instantly. Started it again, ran for 5mins or so then died. After all this had a guy come over and he started yankin on that harness that goes into the back of the injection pump. now it will crank over but not start and the wait to start and od off light are on when they key is at the off position but not when the key is turned on.... Was just wondering if anyone had any ideas, Could that overcharging cause my ecm to take a dump? Also when turning key to the on position there is a loud click from the engine but its down by like the ac compressor sounds like then when I turn the key off it clicks again, and that happened after the guy was yanking on that harness to.
