- Replies 29
- Views 6k
heirloomdiesel 12 posts
angus 7 posts
Mopar1973Man 2 posts
pepsi71ocean 2 posts
Already know my VP44 is on its way out. Other than having to warm it up considerably before it will perform decently I really hadn't had much of a problem with it. Around 14 mpg on the highway and such. Now I get home from being out of town and jump into my truck , which by the way was used by my wife with no problems over the weekend. Now the tranny is acting up. Will sometimes not shift into drive or reverse when i move the gear selector. When it does shift the only way I know its shifted is by pressing on the gas and it creeps forward. Drove it around the block and it wasn't shifting into second and was racing or flaring or whatever you call it. Checked the fluid and its at the right level but it looks like its Dark Purple, not a redish purple like most tranny fluids I've seen but like Barney the purple dinosaur purple. I plan on changing the fluids and someone mentioned in another forum the rpm sensor. I was thinking of doing the pressure governor solenoid and switch. Not sure how to proceed after this. Can't believe this truck drove and ran like a bat out of hell when I bought it back in September.
