Hard start, hot or cold.
- Replies 25
- Views 13.7k
fire176969 13 posts
dripley 4 posts
pepsi71ocean 4 posts
Mopar1973Man 3 posts
Started having an issue a couple days ago. Had to crank the engine over way longer than normal. Drove to work and shut the truck off and it started right back up. Tried about 15 minutes later and the hard start issue returned. The angle the truck is parked doesn't seem to have any effect on the issue. Have tried completely removing the edge comp and it was no help. Checked for any codes, none stored. Checked over the fuel system and didn't have any leaks. Has bluish white smoke when it does finally start. Seems to start easier and faster if I give it a little throttle while cranking. Runs great after getting it started.
Thought it could possibly be the injectors leaking into the cylinders causing it to be hard starting.
