Bad miss while cruising
- Replies 13
- Views 3.3k
jason herdahl 5 posts
Mopar1973Man 3 posts
gassernomore 2 posts
Wild and Free 1 post
Hey guys I've been having this issue for a while now and I can not figure it out. My truck has a bad miss when cruising through town and about 35mph in 4th gear rpm is around 1500. It will do it in any gear in the 1400-1800rpm range it's just worse at 35 and 55mph. Its not throwing and codes and I just put in a new IAT and crank sensor neither have changed how it runs. I put a map sensor in it last summer so that's fairly new also. It does it with and without the quadzilla plugged in and ive had a few different injectors in it in the past year and all have done the same thing including the stock injectors so i dont think that could be the problem. Could it be the APPS? Anyone have any ideas? Thanks in advance guys anything might help me out. The truck is a 99, 5spd, it has an airdog 150, CAI, quadzilla ADR 4k, 7x14 sac injectors, hx52,
