- Replies 24
- Views 5.5k
pepsi71ocean 10 posts
hex0rz 6 posts
JLandry 3 posts
Rogan 2 posts
So, I decided I would give my injectors a little looky-loo. A few days ago, I did this. After fumbling around trying to figure out what wrench size the injector lines were, I got a wrench on them while the truck was running and all of them responded to them being cracked open. I was not able to get to cyl. #2 and #6. Is there a way to get to these injectors?Also, it seemed like it took a good amount of force to crack them open. I have never heard of a torquing device that would use an open-ended application like a wrench. How do I know if I tightened them enough or not enough?I have been avg. about 16mpg now after my BHAF install. I'm curious to see how my injectors are doing as I have not serviced them, and I have no clue if the previous owners have done any at all. I'm curious to see how they are spraying, but I figured I would atleast see if they were functioning properly.Is there any injector bench-testers out there I can buy? I have a link to building one, but I dunno if I can find a steel line and fitting for the injector to do it with...
