New problem #1 injector leaking
- Replies 12
- Views 2.6k
JJK98CTD 5 posts
dripley 3 posts
CUMMINSDIESELPWR 1 post
shanebob 1 post
Hello all, I believe I have a bad connector ring O-ring on injector #1. I can see it weeping. I loosened the fuel line and tried to see if seated correctly, that looked to be good. That is why I'm suspecting the bad o-ring. Seems like a easy fix. Do I really need that tool from Snap-on to pull tube out? Also if anybody has part number for them, from Cummins or the dealership. I would appreciate the info.Thanks,John
