- Replies 6
- Views 2.4k
Mopar1973Man 2 posts
JOHNFAK 1 post
dripley 1 post
hex0rz 1 post
So I was under the truck looking things over and I noticed that it does not look like these trucks do not have oil coolers? Or is the oil cooler integrated with the radiator for the engine coolant?The automatic has what looks like a heat exchanging system to the coolant and then the fluid goes to a radiator in the front?Are these systems adequate if I'm going to be towing/hauling stuff? I plan on getting a 5th wheel in the future. Probably won't buy anything that grosses over 13k pounds.
