May 30, 201214 yr no one has them in stock that are reasonably priced how a bout contagious diesel any feedback
May 31, 201214 yr Bosch rv275's are the same anywhere as long as they are Bosch. no matter where you get them. Price should be the only differance.
May 31, 201214 yr Bosch rv275's are the same anywhere as long as they are Bosch. no matter where you get them. Price should be the only differance. Jacob at diesel auto power should have them - either on new bodies or cores (different prices.). I havent run contagious diesel - I think they are a good builder - I would be curious to run them myself and was in contact with them recently.
May 31, 201214 yr Jacob at diesel auto power should have them - either on new bodies or cores (different prices.). I havent run contagious diesel - I think they are a good builder - I would be curious to run them myself and was in contact with them recently. I forgot that he does sell rebuilt rv275's also. The ones I was speaking of are new ones.
May 31, 201214 yr Jacob at diesel auto power should have them - either on new bodies or cores (different prices.). I havent run contagious diesel - I think they are a good builder - I would be curious to run them myself and was in contact with them recently. Bought a set of new ones from him myself... Easy deal.
May 31, 201214 yr I forgot that he does sell rebuilt rv275's also. The ones I was speaking of are new ones. Id have no problems running the used cores. He flow tests and balances them - well he says so - so Id just ask that. Most vco injector failures are supposedly in the nozzle itself. Most aftermarket injectors are generally built on used cores.
May 31, 201214 yr Id have no problems running the used cores. He flow tests and balances them - well he says so - so Id just ask that. Most vco injector failures are supposedly in the nozzle itself. Most aftermarket injectors are generally built on used cores. Thanks. You just answered a question I was about to ask. I need to do injectors and money is a bit tight right now.
June 1, 201214 yr Author thanks guys there on the way from dap good price and good reputation now i got to set some time aside to install any tips i should know of? seems pretty straight foward.hope i pick up some extra power and mpgs.keep you guys posted
June 10, 201213 yr We now have over 150pcs of rv275 in stock. They were on back order for months (Bosch what were you thinking...)Price did go up a few $ but still a great deal for a new injector.
