Tranny Temp Sending unit location
- Replies 7
- Views 2.7k
mohok 2 posts
gassernomore 2 posts
Wild and Free 1 post
AH64ID 1 post
My sending unit is located on the upper right (top) side of the tranny above the pan. It is a Banks gauge and the instructions say the best place would be in the pan where the temp is the highest and recommends that location. The instructions also provide an alternate location for the 47RE tranny. The instructions say to locate the rear servo test port on the right rear side of the tranny and install the 1/8" NPT temp sending unit there. Mine is in neither of those locations. I was told by tranny specialist the my location was giving me a higher reading and should be relocated to the side to read the temp of the return side. He said to deduct 15 to 20 degrees from my reading. He also said the tranny temp should read lower than the engine. Comments, clarification, and direction, please.
