new diesel enthusaist
i recently got a 04 2500 put a s@b cold air on. looking to improve mileage any ideas or thoughts also helpful. and curious about diesel fuel additives
  • Replies 11
  • Views 3.6k
Welcome to the family...First off the S&B cold air becareful with those kind of filters it doesn't take long for the media to wear out and be passing dust into the engine. If wash the wrong way you can be placing dust and dirt on the inside so when it dries the engine inhales it. As for fuel additive the only additive I use is 2 cycle oil nothing else. Cetane booster tend to reduce BTU content and MPG's. Injector cleaners tend to damage the injectors and pumps. But with CR engine it 200:1 ratio not 128:1. I would highly suggest you upgrade fuel filter to protect the injectors from damage.The biggest thing to improve MPG is to slow down! The second one is reduce your rotational mass/rolling resistance in other words use smaller tires with a narrow footprint.
Quick bit of math...34 Gallons x 128 = 4,352 ozs of fuel4,352 / 200 Ratio = 21.7 Ozs of OilSo this would be first dose... All following doses would be change the gallons to the amount pumped and it will figure out the oil amount...For example:14.783 Gallons x 128 = 1,892 Ozs of fuel1,892 / 200 = 9.4 Ozs of oil.Simple right? :shrug:
Welcome. i think you need 22oz's per full tank. I am sure Mike will have the calcs prtty quick. Good advice on the mph. I just cant seem to abide by it as well as he preaches. But it does work !!!11
Mike just typed to you the best way to improve your mileage...................SLOW DOWN!!!! Speed not only kills people, it kills mileage.
The best way to learn to slow down is to put an egg under the "go pedal" and try not to break it when driving!!!!:smart:
If you think I'm kidding....................I'm not!!:2cents::duh:
From 55 MPH to 65 MPH the wind drag doubles...From 65 MPH to 75 MPH the wind drag doubles again or 4 times as much as 55 MPH.You get the picture the wind drag is exponential so the faster you drive the worse the drag becomes QUICKLY!.
Spike, welcome to the sight. Keep your foot off the go pedal is the biggest help.
Welcome to the fam, what kinda mpg are you getting on average? I use 1oz of 2stroke per gallon of fuel so no (simple) math needed.:think:
200:1 ratio math...(Gallons of fuel * 128) / Ratio) = How much oil to add.So say your tank is 35 gallons.(35 Gallons * 128) / 200) = 22.4 OuncesSo say you stop in and put 10 gallons in...(10 Gallons * 128) / 200) = 6.4 OuncesNot hard at all and can do it on a cellphone...
200:1 ratio math... (Gallons of fuel * 128) / Ratio) = How much oil to add. So say your tank is 35 gallons. (35 Gallons * 128) / 200) = 22.4 Ounces So say you stop in and put 10 gallons in... (10 Gallons * 128) / 200) = 6.4 Ounces Not hard at all and can do it on a cellphone...
Speak for yourself Mopar Man.:lmao::lmao2::lmao:some of us are electronically challanged.
