Hydraulic Injection Injury
- Replies 7
- Views 9.1k
flagmanruss 2 posts
hex0rz 2 posts
98whitelightnin 1 post
Rogan 1 post
Alright, I did a search on the subject here on the forum and came up with nothing. Maybe I searched wrong or something? Maybe it has not been discussed, or much if at all? I sincerely think this is an issue that needs to be brought to attention!
I learned about this type of hazard a year or so ago, but did not realize how serious and how much of a presence it can make in our everyday lives. I just got through with my extrication ops and we learned a little about it so we could be aware of it. It was also the first time I got to see some pictures of how SEVERE an injury it can be!
Being that we deal with high pressure diesel, I think it needs to be brought to attention. Now, not only for our trucks, but for also everyday things. People need an awareness to this issue. I dunno how the p7100 or cp3 systems work, but I do know on the vp44 system, everything after the IP is at around 4500psi.
ANYTHING over 100psi is enough to penetrate your skin! 4500psi is more than enough to do serious damage. Think about what your potentially dealing with and be aware of how bad you could be bitten by it. Even wearing gloves will NOT protect you!
DO not stick your hands or fingers over ANY hydraulic leak! High pressure hydraulic fluid can penetrate through gloves and THROUGH your hand! The injury itself will not initially look like an emergency situation, but it is. You need to get to the nearest hospital ASAP.
I know I personally have stuck my hand in front of a pressure washer nozzle to clean my hand off. I could have EASILY caused an injection injury to myself. It does not matter what type of fluid that has been injected, at best it will cause tissue damage. Although, the worse the chemical injected, the worse the injury can become!
I will include a couple sources on the issue so people can gain more knowledge on the issue:
http://lifeinthefastlane.com/2011/05/high-pressure-injection-injury/
^Read the description and then click on the Q(uestion) dropdowns for further info.
http://www.youtube.com/watch?v=KgtqCUF1E5A
Here are some pictures:
***********GRAPHIC***********
^Look at how minimal the injury seems on the outside.
^Here is what can develop from it if left untreated or if its a severe enough injury.
Remember, anything that causes a fluid to be circulated and/or discharged at pressure ABOVE 100psi, can cause an injection injury capable of these types of injuries!
