- Replies 8
- Views 2.6k
JOHNFAK 2 posts
hex0rz 2 posts
Mopar1973Man 1 post
CUMMINSDIESELPWR 1 post
Aright, I'm trying to diagnose if its my valve cover gasket thats leaking. It may even be an old leak, too. I have some oil staining if you would call it that, that is at the rear. It can only come from the valve cover as it is to high for anything else. I have torqued the cover down and then retorqued after so long. I will double check again to see if it is still indeed leaking.Although, I called O'reilly's, and they sell the gasket for $126! WHHAAATTT!That is out of this world! Where could I get one cheaper?
