- Replies 19
- Views 4.1k
ISX 5 posts
Mopar1973Man 4 posts
flagmanruss 4 posts
dorkweed 2 posts
Not that I'm really surprised.. I think I say everything in the vid that needs to be said. But yeah, that penny rule where if it doesnt cover lincolns head, change it, is probably a good rule of thumb. It isn't the funnest thing having the front passenger side tire blow going that fast and then try and keep it going straight. Something else mighta been going on because it vibrated for a couple miles verrrry slightly before it blew, like a belt let go in the tire. I got a LOT of miles out of them, but obviously tread life isn't the only factor. Age seems to be another. Lesson learned. BUT, in hindsight, I would carry a better jack if you don't have an hour to work that OEM piece of crap, but even better is one that will fit under a 2wd trick with no tire... I drove it into a ditch so I could get some room under it and dig a hole. Which takes us to the next thing, bring a rug or something lol. Bring a real socket/ratchet. I didn't have any wires showing the tires were just barely having any tread left. So if you pull, this should be a lesson to have good tires on it.. It wouldn't be as fun with a TT. Of course there is the cosmetic damage but my paint is already screwed from I guess some lead based paint changover or somethign in 1997
all I know is the pain turns green and chips the clear coat off.
http://youtu.be/00S0n0P9PUc
