In this thread, we talk about stacking a Smarty & Edge Comp for LESS SMOKE
- Replies 19
- Views 14.5k
CSM 8 posts
JOHNFAK 6 posts
AH64ID 2 posts
98whitelightnin 1 post
Ok, The 2002 I have has 140hp injectors in it. The thing can smoke like a train fired on wet leaves until the turbo spools if I have the sub levels on the Comp over 2. It has good power and adequate fueling at higher RPM as well, and can overload the turbo if I am not careful. Overall the truck has more than enough power, I don't need more. I've lit up the new 285 BFGs on dry pavement while rolling before, much to the wife's dismay. :lmao:What I do want, is to keep the timing of the Comp at 5, while reducing a bit of fuel at higher RPM and a fair amount less at lower RPM. Ideally, I would change to smaller injectors, but since I have a smarty and edge, why not do it with electronics?The way I understand it, stacked, the fuel would come from the smarty, but the timing would come from the edge. All I would need to do is plug in the smarty and change the software.Would running the Comp on 5, and then running the smarty at 2 or 4 do what I am looking for? Less overall fuel, while still keeping the timing? I know Mike has played with this, but I haven't yet. I am also kicking around the idea of turning the comp off for the winter, and trying out Smarty's winter fuel software for A/T trucks... Anybody try that?
