Fuel psi from 20 to 13 psi???
Details on truck in question are in my sig. Video starts from 25mph up to about 70mph. WOT the whole way, and let off right at 3,000rpm... Seems like a big drop for an AD165 on a stock truck.... Cruising around town, and on the highway it holds 15-17psi
Posted Image
  • Replies 20
  • Views 4.1k
That does seem like quite a drop. Could be clogged inlet or filters? Has it always done this or just recently started? Even my smaller 100 doesnt drop anywhere near that much at wot.
The AD system is 3 months old, how could anything be clogged? I just got the gauge hooked up yesterday, so i don't know how long this has been going on.
Did it always do this since the install? Might there be a colapsed suction line OR the bottom of the draw straw hitting the bottom of the tank, restricting the flow?
The AirDog 165 does not use a draw straw like the 150. You modify the sump that is in the tank. I followed the directions to the T. The way the tube pulls gueo threw the sump it cant sit right on the bottom.
Clogged tank vent? Check after a run by slowly unscrewing the fuel cap. If you hear a hissing sound the vent is clogged. Happened to one of my trucks.
Hmmm I have noticed a hissing sound at the pump when taking the cap off. Can you explain why that will cause what o am seeing?
It could be in there for 3 days and still be clogged. Could o picked something jp from your tank or some bad fuel, just a suggestion. I always check the easy things before replacing anything
Lift pump will have to work much harder and loose pressure when the fuel tank can't breath. As you use up fuel air needs to displace the spent fuel. The OEM vent goes bad sometimes. I think I heard it's got a check ball that acts up sometimes. The check ball is in case of a roll over so the fuel can't leak out the vent. I put on my own vent to the left of the fuel cap.
Makes since to me, So I should be able to leave the cap loose or off and take it for a test drive and that should tell me instantly if that was my issue.
Are you using the factory fuel filter as well because of the fuel heater? I have had dirt settle at the bottom of the cannister and then play havoc with my pressure as well. Isn't there a screen on the inlet side of the AD? Could possibly be clogged a little.
Yeah that too..... it's important to have a filter in front of the L/P. :thumbup2:
No, the canister is long gone. where is the screen at?
No filter infront of my AD. The filter is built into the base.
There is a restriction some where for sure. Old School AirDog 150.. Center gauge. As you see it get down to 15 maybe a bit lower but not much. 2-3 PSI fall is typically for mine. Now I'm set for 19 @ Idle and 17 @ WOT. Now on the return trip I suck air bubble pressure will fall out.
http://www.youtube.com/watch?v=grl72Up-8T0
http-~~-//www.youtube.com/watch?v=grl72Up-8T0
Thanks Mopar! I did watch your video, and thats kinda why I am here. I figured something was wrong... I am running the Isspro gauge you linked in the post with this video. I bought th napa valve pn 6820, and also the air line you used. I would assume that there would be something in the tank, maybe the pickup tube? I helped a buddy install a 150 a wile back and his had a draw straw. Mine modified the sump. There was 2 screens, an inner and outer. the inner screen was removed so the new draw tube could pretty much sit right next to the outer screen. there is little bracket it fit into that spaced it from the screen if I remember right....
Air Dog with quick connects are prone to suction air leaks. :rolleyes:Change you plumbing back to old school JIC and Pushloc's and most of the problems go away.
Air Dog with quick connects are prone to suction air leaks. :rolleyes: Change you plumbing back to old school JIC and Pushloc's and most of the problems go away.
:doh: anyway to verify that is the issue? If that is an issue, I can just change out the fittings coming from the tank to the LP correct? It wouldnt suck air being pos pressure from the LP to the IP would it?
Just for the sake of trying, I took the fuel cap off and drove up the road, same results.
Eric at Vulcan Performance sold me the fittings to get rid of the quick connects. He was not surprised I wanted them gone. They just don't allow you to put the stock pump back on if your airdog raptor ever goes south. Eric did say he's told A/D they need to get rid of the quick connects cause they do leak air in.
If you dont mind me asking, what did it cost to change the fittings? Kinda crappy I have to spend money on this... :spend:
Eric charged me 10 bucks for them picked up at his door. He's one heck of a good guy to do biz with. That's one thing I'm sure of :thumbup2:
