What's the difference??
Anyone know the difference between the Cali 235 and the not-Cali 250? Is it just the ECM or something different? I just jumped to a 04 Cali Cummins SO....
  • Replies 16
  • Views 4.5k
I have always heard that a smarty sr will change the programming to the Bo 305/555 setup plus add the power that a smarty does to a 305/555 truck.
Just the 'puter from what I remember reading!!!! That said, AH64ID will have the answers for sure...................just hang around a bit!!!!!
You mean the SSR? Or is the sr a different model?
My 04 is the cali model and with the smarty you will never know the difference
- - - Updated - - -
They are referring to the S-06 which is the sr model of smarty compared to the J-06 which is the jr model. The jr has 3 power levels and the sr has 10.
The difference is programming. I think the piston cooling nozzles are different between the cali/so and the HO. Yes a Smarty takes a cali/SO and then makes them a HO and then adds power.That's the motor, other differences may be a 47RE trans or 10.5" rear axle, but I think that was isolated to the MY03 trucks.
So if I got a new smarty and put the "Return to Stock" I'll get the HO tune?
No, stock will be stock (SO or Cali), but the modified tunes are based on HO tunes.
This is off the Mads website
Q. Which version of "stock" will the Smarty come with.
A. Smarty does NOT download the complete original software from the ECM and does not store it into it's memory. That
is for a simple reason. The protocol in the ECM does not allow to read the flash memory.
How can Smarty then return to stock? Simple he has all the latest stock softwares already on board. When you choose
to return the truck back to stock, Smarty takes the stock software from it's memory and updates the ECM with that
software.
Correct, but it puts the stock software for your OEM configuration back in. If it were to make a SO an HO on the stock tune then it wouldn't have been undetectable by the dealership.
:ahhh:Man I need to play catch up, yall talkin greek.
So let me get this straight.....me having the Calo/SO, if I put the Smarty on the 60hp no added timing setting, it will change my "base tune" to the HO (50-70hp gain) AND add the 60hp Smarty tune totaling 110-130 gain?
Yes Sir, that is the info as given by MADS.
I thank the Cal had a cat in line and different timing.
