- Replies 7
- Views 2.8k
AH64ID 2 posts
Rogan 2 posts
Mopar1973Man 1 post
Cummin Dodge 1 post
Well on my way back to a job to finsh up for the evening I was getting back up to highway speed little heavy on the throttle and pulling along rather good and strong then BAM! It fell on it face. I look down and the Edge Comp blinked off for about 1 second and then back on. But there was no power change still flat.
I'm thinking the Edge comp finally died on me with a bit more than 5 years of service. So I get to my job and was early so while I was sitting I tried changing the the levels it was locked on 5x3. Huh? So I turn key off and unplugged and replugged the Edge Comp module hoping to clean up the connections a bit. Sure enough I fired it up and Edge Comp responses again. Right on! So I'm going to have to pull the truck in the shop tomorrow and look over my electrical and maybe add a bit of di-electric grease to things. But I figured I would share my tale with you all.
