Leaking Overhead Cab Marker Lights
- Replies 21
- Views 6.7k
JAG1 6 posts
flagmanruss 5 posts
Rogan 4 posts
Mopar1973Man 3 posts
Anyone know if it's just the screws that leak? I changed out all the little plastic washers under the screw heads using neoprene washers from pole barn metal screws. Seems to gasket pretty well but, wondering if the leak comes from the lens base instead. I was afraid to pull them up since they are stuck on. Might tear the gasket underneath. Tell me where the leak comes from :ashamed:TIA.
