- Replies 19
- Views 2.9k
olred92 4 posts
Mopar1973Man 3 posts
flagmanruss 3 posts
ISX 3 posts
Well I had a major case of bad luck this morning. I had truck loaded and trailer hooked up to carry off a load of scrap metal and went out to start the truck while I checked tires and straps. I had brake brake set and a block in front of trailer tires. shut the door and started back to trailer and the d**n park brake let go with truck facing down hill and then the trailer rolled right over the block and truck took off down hill. I tried to catch it but ended up falling and getting run over by back truck tires and trailer tires. I had to lay there and watch my truck roll through a small thicket of brush through the barb wire fence twice and the hit a tree. I couldnt get up as my leg was hurting so much and all I could was I broke it. I finally started to feel my leg and could move a little. Finally able to get up and limp down hill to check on truck that was still running. Looked for leaks and gathered up what had fallen off trailer and moved truck and looked at the rest. I know have another big dent in bed of truck, alot of scratches from the barb wire, a chip in windshield, busted grill, and the new bumper I put on now needs the new plastics, and it messed up my fuel pressure guage somehow. I am ok and just have a slight limp anymore. Good thing it didnt mess up my knee that just fixed 4 months ago(hence why I fell as hamstring still isnt as strong as it should be).Has anyone else park brake just let go at random moment?
