Injector Sizes And Turbo Discussion. . .
- Replies 26
- Views 53.1k
Texas CTD 6 posts
adamey1000 4 posts
CSM 3 posts
Mopar1973Man 2 posts
#1 - I'm not an expert, and don't really have any personnel experience on the subject. #2 - This info is probably not going to be dead on or 100% true, but that's kinda gonna be the point of this thread. I want opinions voiced, and I want to be corrected if I'm wrong. Some of this info is old news to some of you, but I hope it could help some newbs that are wanting to upgrade injectors and/or turbo(s). First I'm going to post roughly how much horsepower a specific size 7 hole injector will add: (I use 7 hole, because it is the most common injector in a 24 valve - 6, 7, and 8 hole can be used on a 24V) 7x.0071 = Stock HO 7x.0075 = Stock SO 7x.0079 = RV275 7x.008 = +60HP/+70HP 7x.009 = +100HP/+125HP 7x.010 = +150HP 7x.011 = +175HP 7x.012 = +200HP 7x.013 = +225HP 7x.014 = +250HP Keep in mind, a specific size doesn't mean it adds a specific horsepower; it just depends on the injector. Here's some links to some very good information on injectors and turbos: 1( http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/216421-injector-myth.html 2( http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/216850-all-injector-info-youll-ever-want.html 3( http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/219043-injectors-turbos.html 4( http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/585794-turbo-spec-compilation.html As the first link talks about, a 7x.010 injector will work fine with an HX35, as long as there's not a wire tap programmer being used. It will just be very smokey. As the last link states, with a 7x.010 injector, a 62/68/12 turbo would be a nice application. With a wire tap programmer, a 62/+71/14 turbo would be a better application. Like I said at the beginning, I'm definitely not an expert, and I'm still a newb myself, but I wanted to get the ball rolling, even if my information is not detailed, or if it has errors, (which I'm sure it does) that's kinda the point; I want to hear different opinions on different turbo/injector setups, and and what worked best for your truck, whether you daily drive, tow, or sled pull. Y'all just pile any injector/turbo questions and information in this thread. Somebody with some first hand experience chime in, and correct all my mistakes.
Thanks to JohnFak for more info:
