All diesel do that it's normal.....lol
- Replies 9
- Views 3k
Mopar1973Man 1 post
ISX 1 post
dobienut 1 post
Texas CTD 1 post
So took a trip up to a local dealer who on rare occiasion's get's a Diesel truck in on trade for a new car/truck. He had a 2007 Dodge Cummin's From 20 feet the truck looked great all clean and shinned up. At arm's length tottaly different story. The truck was locked and i motioned for a salesman to come over. After a few polite's i asked him for some info and backstory on the truck. He said the previous owner told him it was a One owner low mile's 2007 dodge 3500 with a 6.7 and was totaly stock just debagded and Flatbed added .... Apperentaly they took the man's word and never even poped the hood or drove it!!!! He give's me the key's first thing i see is that it was not a factory dually so i keep looking to find that it was a 2500 with a set of dually wheel's. I told him the info he looked pissed he was told it was a 3500... Then i poped the hood to see a 5.9 under there and then informed him of the difference between a 6.7 and a 5.9 His face was blood red at this point. I noticed the velcro on the fuse panel and the cut wire harness and told him it was once chiped. The worse part was when he said it was adult owned never even used to pull with(Which was bull due to the fact the Gooseneck ball was pretty wore and had 5th wheel hole's in the bed and the resse hitch square was horribly wallered out) The Exhaust manifold shield was so black and red from extreme heat and the turbo was all kind's of color's. Then i laid down on the ground to take a look oil was coming from every where mostly from the rust hole in the patched on exhaust a huge puddle of oil under the truck nearly a quart. I assumed the turbo was shot I said "Did you not see all the oil leaking when he brought the truck in???" his reply "Well that just a Diesl thing all of them leak oil really Bad no worry"... He then asked if i wanted to start it and here it run i said "No you will do alot of damage if you do." At the point he fired it up and a bellow of oil and white smoke rolled out the exhaust tip. He then reved the truck and of course more oil flowed out. He said "Hop in and drive it down the road" I said "No way" so he replied "Hop in i'll drive it" Needless to say we went about a half mile i noticed the odometer didn't work(hence the before metioned low Mile's) and the trans was slipping horribly and the low oil light poped on so i reached over and turned off the key shoke his hand walked away to my truck He ran up behind me I turned around he looked me right in the eye and said $27,500 and you can drive it home....Needless to say I didn't come home with the truck...He has now lowered the price to $12,500 in only 2 hour's. I don't know if I feel sorry for the guy cause he might have gotten taken on the truck or the fact he was furious that i seen all of it's flaw's and called him out on it as he was tryin to unload it on me....
