Tapped Fuel Filter Cap
Does anyone still make a tapped fuel filter cap for the 2000 - 2002 style fuel filter assemblies. I checked GENO's and he doesn't carry them any more apparently, and a Google search didn't turn up anything. Just looking for an easy way to bleed air out of the system after filter changes since this is the highest point in the system. Thx
  • Replies 20
  • Views 4.7k
The stock cap is cheap, brittle plastic that would most likely crack. Plus the hex in the center that is used to remove it is hollowed out to reduce material. The resulting "hole" is approximately 1/2" to 5/8" so the resulting drill and tap size would be large as well. If I pick up a used one I might try it but I don't have much faith in it holding up well.
Why not just cycle the lift pump, and bleed the air at the VP inlet??? :shrug:
I'm not worried about bleeding air. I would like it for a sample point for fuel pressure. I'm full 1/2" fuel line without any pressure ports. I figured the cap would be a great place.
I thought all big line kits came with a tapped elbow?Cut your 1/2" line between the VP and the filter housing. install a tee with 1/2" push loc fittings, and on the "tee" side, adapt down to 1/8" NPT, and stick a compression fitting on it.
when i prime from a dead empty filter assembly, i crack the lid to it just enough to where the lift pump will fill it up and start spitting it out and that is when i close it up. never had a problem with this method aside from a bit of mess that goes away after a while.
Is it necessary? Isnt there a schrader bleeder on the side of your VP44? I know mine has one. Bleeding the fuel filter canister and VP44 is very simple. Bump the key, lift pump comes on for 30 sec, push the scrader pfffffft! air shoots out then fuel and you are good to go
I wasn't looking for assistance, advice or opinions on how to bleed the fuel system on my truck. I asked if anyone knows of a company that still sells a tapped fuel filter cap for 2000-2002 trucks. Thx to assistance of one of the forum members I was able to find a used one. Still haven't heard of a company that currently sells them.
please dont take offense to anything outside of your initial question. we are all trying to help in what way we know how. :)
No offense taken, just trying to keep the focus on the topic. I asked a simple question and got lots of answers and questions to an unasked (but frequently asked) different question. Been turning wrenches for 4 decades and I'll be the first to admit I don't have all the answers. That's why I check this forum often, it's a huge wealth of info. I also understand that everyone is trying to help and it's difficult to gauge each members knowledge/experience. They don't give a score for that. Thx
well as others and like me can see the purpose of having a bleed on the cap, there is no need when there is a bleed on the vp that will accomplish the same task. we offered alternatives to your question knowing there isnt a product out there anymore along the lines of what ya seek. :)
The "bleed" on the pump is installed as a way for techs to monitor FP and is not ideally located to serve as an air bleed. Air always accumulates at the highest point in fluid systems and is where air bleeds if installed are located. 8 days after a filter change my fuel gauge is still fluctuating from trapped air. After I finally get all the air out, the gauge is rock steady.
i will agree with you fully, but on a dry empty system, one could open that schrader valve and allow fuel to flow/pushing what air out it can. the rest will get burped out of the system through time.
If it's at a high point in the fuel system doesn't matter. With the lift pump running, (bump the starter for a second) all air will expel from the filter canister AND the VP via the schrader on the side of the VP simply because the fuel is being forced by the lift pump. The whole deal only takes a few minutes. Couldn't be any simpler. There really is no need for a bleeder on the fuel cannister cap. The bleeder on the VP will purge air from the fuel cannister and VP. Here is a vid demonstrating this. Made by a guy in hawaii:
All I was looking for was a different cap, Thx everyone for all the wonderful suggestions. The original question still stands, does anyone know a company that sells the cap I'm looking for. If you know of anyone I would appreciated it if you would provide that info. If no one knows of a company that can provide the product then I will keep looking. I started this thread with one question and only Ryan has provided input on the original question, Are there other ways to accomplish the same task, in almost every case the answer is yes. This is the way I choose to accomplish the task. Is this the same way you do it, based on all the input apparently not. Sorry, but I reserve the right to be different.
