- Replies 16
- Views 6.5k
Wild and Free 6 posts
CSM 3 posts
hex0rz 3 posts
Rogan 2 posts
There has been a lot of discussion about oil samples lately and another member had a sample with high Silicon in his sample and after a few questions found he had a good chance of contaminating the sample with dirt while taking the sample the wrong way. I took some pics of a couple different tools to do it the correct way to eliminate the chance of dirt in the sample. There are 2 different tools to get this done and I will attach pics of both here.
- - - Updated - - -
Here is a pic of an oil sampling gun with hose and sample bottle attached, also in the picture is an oil sample port that Cat uses on all of the component on their newer equipment, I also have one of these installed in my system for easier and cleaner sampling than the sample gun.
Also as you can see the sample port fittings come in either o-ring boss or pipe thread to accommodate different places you would want to pull a sample from, Cat uses almost 100% o-ring boss fittings. In another pic shows the yellow rubber cap that covers the fitting and as you can see it is labeled as engine oil, on the Cat equipment different components have different colored caps and are labeled hydraulic, transmission ect.
