stabilizer links, and steering box adustment
- Replies 25
- Views 5.8k
dripley 6 posts
MnTom 4 posts
Dave3500 4 posts
diesel4life 3 posts
I just put on two new stabilizer links on the front. No problem installing them except for knowing how much to tighten the nut down on the bushings. They tightened easily until I ran out of threads. Is there a proper squish value on the bushings? I also tighten sector shaft adjustment on the steering box about 1/8 turn and it seems to be working better on the test drive here at home. I am leaving for Indiana shortly and will put it to the test then.
