Does a 12V really need 2-stroke?
- Replies 10
- Views 6.1k
Mopar1973Man 2 posts
guesswho512 2 posts
Taz 1 post
Wild and Free 1 post
This topic is now closed to further replies.
In short, yes. Though we will not have devastating results from not using it like the next generation cummins, it does help the lift pump and all parts of the fuel system. I noticed a ticking in my lift pump one day, dumped in some 2-stroke and it fixed it right up. Another thing I noticed was it does not smoke as much in the morning with the 2-stroke. Having the timing up, the beast hates the cold and smokes like a freight train until the EGT's are over 400, but the other day, I started it and couple minutes later went back over and said uhhh, wheres the smoke! All I saw was a blue haze instead of a white cloud. I am not exactly sure how 2-stroke can have such an impact on smoke with a cold engine but the results were obvious. I also believe it helps with MPG, the added power is enough to keep you off the pedal just a little bit more keeping you over 20 as long as you are under 75mph.
