- Replies 20
- Views 7.1k
dripley 7 posts
GreenRiverCummins 5 posts
stodg73 2 posts
hex0rz 2 posts
Alright only a day before i take my big Camper on her first maiden voyage(with us that is). While in town cashing my check and getting Diesel $100 worth... I felt the clutch pedal was sponge like and pushed to easy compared to normal. shifted the same ran the same. Till i got home pulled in to the drive and started to back up but couldn't get it to go back in gear. Shut the truck off put it in first pushed the clutch in fired the truck back up. Let out the clutch truck rolled forward as normal then stoped repressred the clutch and wouldn't go back in any gear. Let the truck sit and cool for 3 hour's came back and it's back to normal now. Called a trans shop talked to him he say's it deff not the clutch or the presure plate he is sure either the fluid is weak or it has air in the line or just a bad slave clyinder. But thought i'd run it by ya'll before i pull my big camper in a few day's. on a side note the fluid in the clutch resivor on the firewall is orignial over 185k on it might need to change it. But will await ya'lls input thanks again.
