Tried everything short of "star torque"
- Replies 6
- Views 2.2k
Mopar1973Man 1 post
Wild and Free 1 post
JAG1 1 post
mopartechnician 1 post
(Torque till you see stars) I've read ALL the related threads and I've tried everything I can think of to get 3 fuel lines to seal at the connector tube joint. Connector tubes got new o-rings lubed with engine oil and pressed in by hand until "click" indicating fully seated past o-ring. Inspected the compression ends of the fuel lines and connector tubes and no signs of damage or over tightening. I lightly polished the fuel line ends with scotchbrite pad. Hand tightened all lines to ensure proper alignment and then bleed the system of air. After bleeding torqued to 28 ft/lb and have small weeping leak at 1, 3 & 4 (go figure, all the connections used for bleeding air from system). Since then I've, loosened the nuts and fuel line clamps, hand tightened and re-torqued & increased torqued to 30 ft lbs then 33 ft/lbs twice and nothing has stopped the weeping leaks. Is there anything else to do at this point before I just start cranking on them? I'm fairly certain (99.99%) the o-rings aren't damaged which only leaves the compression joint as the source of the leak. I let it set for 36 hours to see if there was going to be a hard starting issue and it fired right up. I hate to just start reefing on them because I know better but at this point the only other option is new fuel lines and connector tubes with o-rings. Sorry for the long post but want you to know I've tried all routine suggestions.
