- Replies 10
- Views 2.6k
Ironforger 4 posts
MnTom 2 posts
dripley 2 posts
Ilikeoldfords 1 post
Getting ready to purchase gauges.What is the typical factory boost pressure range? Trying to decide on a 10 - 30 psi guage or 10 - 50 psi.Also, I'm going to install an EGT guage as well. Were do most guys put the thermocouple probe? I'll probably drill a hole & tap 1/8 npt on the top of the exh manifold pre-turbo - that is right there before the flange where the manifold bolts up to the turbo. That's where I did it with great success in my isuzu NPR diesel.And for you guys who are going to warn me about metal drill/tap chips falling in and wrecking the turbo, don't worry as the best way is to drill and tap slowly while engine is idling. Thats right! Get up there and drill while engine is running. Preferably do it on first start up of the day as it only takes a couple minutes and you don't want to work on a hot engine. As you poke through, the pressures from the exh gasses blow the chips up and out. Just be sure to wear safety glasses!Soon to be installed mods: fuel bossPotential future mods: 50hp injectors & edge comp.Thanks!
