My Catch can/ vapor canister
- Replies 23
- Views 17k
Ilikeoldfords 5 posts
Bronze_Bandit 5 posts
diesel4life 3 posts
Mopar1973Man 2 posts
I just threw this catch can together with some 2" abs pipe and fittings from home depot for about $30. The hose was previously hanging down just past my front sway bar so it didn't get any oil on the engine or rad but it would still drip on my driveway and gunk up my steering linkage, front axle, underside of the engine and I had a habit of hitting my forehead on it whenever I would climb under the front of my truck...so I decided to make a canister to contain the oil but still let the gasses out. It has a chunk of steel wool in front of the outlet to act as a filter and a brass drain fitting on the bottom. Inlet and outlet are 3/4 ID hose and it is zip tied securely to my sway bar and steering box brace. I'll get some better pics of it later...
