High Idle Kit Is Here
Update 10/15/15!
The Mopar1973man.com Cummins High idle switches are for sale again in the Forum store
Edited by Me78569
  • Replies 213
  • Views 52.3k
  • Here is mine installed: first post since joining the forum. Routed back around shifter console along firewall
  • I caution anyone renting a Smarty that does not have 600 bucks laying around, they can be quite contagious once you start playing with the upper level tunes. Use at your own risk! LOL
    Split the conversation so we are back on track.
Yankneck696, I just got my gauge mounted fooler today. It looks great and works great. Are you considering building any units for the 3rd gen trucks? My brother has an 05 and he is very interested if you are going to build any.
I'm getting ready to buy, but I wanted to know 2 things-
1. Can the mpg switch can be selected/ deselected at any time- or is there ever really a need to turn it off?
2. Ed, I would like the overhead version- maybe to fit in/on/under the garage door opener compartment- could we work soemething out?
AP
The only time you want to turn off the mpg mode is for cold starts. If you leave it on, your grid heaters wont run at all.
3rd gen works via the cruise control (except real early 03 models) with a dealer flash.
I do not have the upper console, so have no idea of the dimensions. If you could tale yours apart & show pics with measurements, it would be a great help.
Ed
Ed
The cruise control option is different than the automatic option. The automatic (not talking transmission) is enabled on every 3rd and 4th gen truck. It takes coolant below 180, IAT (from MAP) below 66, and ambient below 32( I don't know if it's from the IAT by the turbo, or trucks ambient sensor thou), after 2 minutes it will go to 1000. Still useful for warmup and cool down.
As I mentioned in an earlier post this would work well for most 03's and 10+ manuals as they have no means to increase idle if the ambient temp is above freezing.
Only the very very rare late 03 has the option to use the cruise control fast idle.
Like the 2nd gens with 3cyl a Smarty will enable the cruise control option for 3rd gens.
Does anyone know if the 3rd gen trucks retard the timing when it is cold out? I think my brother is more interested in a mpg fooler than anything. If the timing isn't changed I can let him know and drop the subject.
John, if I can figure it out, would you like to beta test?
Ed
I would be more than happy to test it out for you.
I was going to PM you about getting a 6" ECT sensor extension, I want to run my ECT sender at the port by cyl #2 vs #1 I think it's going to be hotter and run the fan better when towing.
I believe they advance it. Cold air needs more timing than warm air for combustion to occur at the same CAD.
I just checked, same sender for all of them. $15 shipped for the extension sound fair?
Ed
Edited by Yankneck696
3rd Gen, and better make it 8". $15 is very fair, PM how you would like payment.
PP to yankneck696@yahoo.com I'll get it shipped out tomorrow or saturday.
Ed
Yankneck696, when my truck is warm (180-190 deg) and I change the selector over to the 6cyl high idle my oil pressure gauge increases too? When the truck is cold idling I see 50lbs of oil pressure. When it is warm it is just under 40lbs. When the selector is set to the 6 cyl idle, before the truck starts to idle high the oil pressure gauge increases to about 50. Is this normal??
Perfectly normal, your oil pressure gauge is fake. It's run by the ECM in an algorithm of what it should be. Diesel engines have large pressure swings for small rpm changes and dodge got tired of warranty claims for normal operation and took the sender out of the picture.
3rd gen and newer trucks don't even have an oil psi sender, just a 6psi switch. What's funny is the owners manual still tells you to watch for proper oil pressure, even thou it could be 8psi (below the min requirement for idle) the gauge will still show ~40.
I have a real pressure gauge, the only time my OEM cluster is correct is 1300 rpms with a warm engine.
Wow! I had no idea! :doh:  Learn something new every day Thanks!  :thumb1:
I was less than pleased when I found out. And why I have this....
Ed
The part arrived 2 days ago, looks better than an OEM unit. Thank you.
Now to find time to hook it all up.
Please start a thread about it AH, as some others may find they want to do the same thing. $25.00 shipped will be the final price in the USA.
Peeps respect your ideas & I think it's a worthwhile idea. If it takes off, you will get some kinda special consideration in the future.... I have an old Summit sticker I can send ya... LOL
Ed
Guest
This topic is now closed to further replies.
