Front/rear Axle Lube
- Replies 29
- Views 5.5k
joecool911 8 posts
dripley 6 posts
Mopar1973Man 5 posts
diesel4life 4 posts
Is there an advantage to using synthetic axle lube when changing the fluid? Can I use one grade of fluid in both front and rear axles for simplicity. I don't believe that I have the limited slip rear axle.
