- Replies 17
- Views 5.4k
jncornett 9 posts
gassernomore 4 posts
Mopar1973Man 3 posts
LiveOak 1 post
New to the forum previous owner of a 05 common rail.....soon to own 01 24 valve... Thanks in advance.. i just gave my word to buy an 01 2500 4X4 24 valve automatic truck... the truck is being sold because the vp is going out...i looked over the truck it looks fine starts fine but has these codes:ECU, p0122 apps/tps sensor voltage low,p0236 map sensor voltage too high too long, p0522 oil pressure sensor voltage low ,p0562 supply voltage low at ecm, p1488 auxiliary 5 volts supply output to low ECU done, PCU p1693 Pcu done.... am i crazy or did this truck just see low voltage and go to limp mode it was single digits when this happened along with the first and only dead pedal... owner has invested a lot of money and the truck has been one thing after the next and he is off loading it as is.. not spending another penny on it... whats your opinions the truck is bone stock.. new engine with 30,000 on the clock 170,000 miles on the rest of the chassis..
