- Replies 38
- Views 8.1k
								Mopar1973Man 18 posts
								AH64ID 7 posts
								joecool911 3 posts
								flagmanruss 2 posts
I'm on my way of installing solar panels on the RV. These are not going to be roof mounted but free standing. MoparMom and I figure you could just fold up the panels and lay them on the bed while travelling.
Right now I'm doing a bit of bench testing and so far I'm very pleased with the 45 watts worth of solar panels. This solar panel kit is from "Harbor Freight" for $139 buck on sale. Then while I was there I picked up a 1200 watt inverter for 120 VAC power. Figuring against typical Amp hours of deep cycle batteries I figure 1200 watts is more than enough.
10 Amps x 120 Volts AC = 1200 Watts = 12 Volts DC x 100 Amps
Then figuring common RV deep cycle batteries are roughly 100 Amp hours then you have two batteries so that would give you roughly 2 hours of full 1.2kw power in theory. But we know you can't run a battery totally dead nor will a inverter operate below about 10.5 volts.
