- Replies 34
- Views 5.8k
Dieselfuture 6 posts
MnTom 5 posts
mulcher812 4 posts
kedlin88 4 posts
All right, I ordered a new set of RV275 injectors and feed tube o-rings from DAP. They will be here tomorrow. I got all my old injectors pulled today. It was actually fairly easy, I had figured 5 and 6 were going to be a pain but they weren't. I can return my old injectors for a $100 refund but I was thinking about keeping them for a spare set.
I decided to go ahead and take one apart tonight, and noticed there were two washers inside the injector above the spring? I've never taken one apart before, but isn't there only supposed to be one washer? Do you think the second washer has something to do with pop pressure? Injectors wore out?
Also, just to make sure I have the install right,
Apply clean oil to injector and feed tube o-rings
Injector hold down clamp is 89 IN LBS = 7.5 FT LBS
HP injectors lines are torqued to 28 FT LBS which I read is just tighter then snug with hand ( I don't have a crows foot)
Does all this sound right so far?
Any extra tips for the install?
Thanks,
