Pilothouse/RAM3500 build
Edited by PilotHouse2500
  • Replies 600
  • Views 232.9k
yah I have a small cabinet for parts you can hold in one hand.  Way easier than a wire wheel!  :)
with a little help from some friends....
  • Popular Post
car club meeting last night so tossed a few parts on to show the vision...
20191017_164024small.jpg.1474c15cff2e287fedf93f6ff2e9b4c5.jpg20191017_164012small.jpg.31b1f080f2f8fb5082a329be3a7f0d76.jpg
  • 4 weeks later...
spent my weekend getting the requisite cuts on my fingers and stabs in as well...but I learned a few things this weekend:
  1. Minnesota sports had a good weekend (Wild win, Vikes win, Gopher hockey sweeps the Ugly Helmets, and Gopher football beat Penn to stay undefeated)
  2. My air shear handles 16ga no problem
  3. My electric nippers handles 16ga no problem
  4. My neighbor challenges me every step on this project to take it up one step better (more on that later when I can show a picture)
  5. Building a firewall is time consuming
  6. 4x8 16ga sheets are HEAVY and cantankerous.
Looking great, my guess is the cab is coming off a few more times, if you haven't might want to check and adjust the valves at some point with the cab off as it looks like it might be tight later on for the #6. They really don't require a whole lot of adjustment and you would likely be set for a long time.
Also might want to make a short list of items to do while you have good access to the engine. Couple small fuel items on the drivers side and the sort.
But really coming along nice.
I plan a full rebuild and dyno of the engine before I really button things up, regardless the cab will be on and off several times yet.
engine firewall intrusion panel built (and forming buck)
got a little further last night after work:
more progress....done with the 16ga...rest will be 18ga with some rolled in beads for support.
prepping for the rest of the floor....and making "vroom vroom" sounds
20200113_160821.jpg.92c381df14ee30bea15a6b18d67e0c0b.jpg20200113_164710.jpg.99e6f79a632b12743ff2e1bff87c712f.jpg20200113_160849.jpg.e296fba8581590839ac22b109ec27357.jpg
How did the steering wheel feel in your mind?
It had a little play in it...need to fix the steering box!  :ahhh:
Floor supports in
Floor fit and ready for beading and then welding in.
Looking good.
Did you have to give up pants to keep the tranny warm?
On 1/26/2020 at 9:08 PM, dripley said:
Looking good.
keepin' the sparks off the pretty paint!
Trans tunnel built, ready to install
Welded in!  Can pull the cab and spend hours finishing the welding and grinding!
I enjoy seeing the updates. You do nice work, very nice.
