Looking for Staff Members
Edited by PilotHouse2500
  • Replies 558
  • Views 201.8k
Put the new wiper motor in this weekend, complete with twisty mounting bracket.
  • 3 weeks later...
Evap unit mounted.  Sadly with the FW wart I had to move from a center location to the pass foot well.  Driver doesn't need heat anyway...right?  I'll make a duct.
happy wife happy life?   lol heat her feet first.
I'm new to following this thread but man talk about motivating. I was putting some things off on my own projects (nowhere this magnitude) and even contemplating outsourcing some work but I think I've changed my mind thanks to this! Keep going man!
Must be dang cold up there! :lol:
AC condenser "mostly" in....likley I will weld the Z brackets to the frame to avoid the bolt plates I had made to get it all mounted to the frame rail tho....might wait for that till the cab is off next time.
Dropped the rad/fan assy in last night.  OOOO boy is it tight!  But clearance....is clearance.  I have about 1/4" on the passenger side.  I will modify the mounts to allow me to loosen and tip the assembly forward for serpentine replacement (thank you middle of the night engineer brain).
319729590_593304055897599_7951502884656634506_n.jpg.4ce62903c0fc88cbca7f4f0b124823a4.jpg
319676676_843153040349195_8742916094017020630_n.jpg.5323557de042c29fb927d8e772da92c7.jpg
319668209_5867014690028564_830145598086845411_n.jpg.05a153f92a2ccdbd37a64c8de9ab981d.jpg
319183502_1216760332262012_4012401261587767806_n.jpg.2f477b3864ddc3310e0edee8d0c3275f.jpg
Last day of vacation burned, but I got the passenger side drip rail fab'd and welded in.  Being the back half fo the cab is a B1, the rail is different so I carried that thru to the front as well.  Also allows me to get some seam sealer in there when the time comes to keep the rust monsters at bay.
Driver side done now as well.  Puma supervised, sadly she is pretty much deaf so the grinding dind't hurt her ears.  :(
Nice job. Going to take a bit of time to get it perfect but, looks like you your on track for it. :thumb1:
Well, as usual I didn't get as much done as I wanted, but here is the dump of the week off of work I did.  I didn't take pictures of me standing there scratching my head for a few hours each day.    Also, sadly I lost a coworker over the break, my car club buddies dad passed and I got some concerning news over a good friend.
First off, modification of the new brake booster to match the mock up of the old one to fit in the engine bay/behind the engine
Next up was removing the old extra cab mounts I don't need and welding on the front mounts for the 4 bar linkage.
Next we have the old and new rear suspension
Finally there is the hood wings back on with prop arms!
Final good news is my wife is now happy with 2 new familiy members to spoil!
as always awesome pictures.  sorry to hear about you friends
  • 3 weeks later...
After much angst and time and thought and putting it off....the front clip finally has it's home on all the new mounting points.
@PilotHouse2500, forgive me I do not know what a front 'clip' is. Those look like some sort of pivot. Is that so the entire front opens up around the engine? Like on a big rig where the hood and fenders are all one and lift up out of the way?
