2 Questions :)
1. What is the best place to get a front hub assembly on a 2001 2wd 3500? Mine is howling like crazy and I suspect is part of the ABS problem I am having.
2. I looked but couldn't find what type of power steering fluid my truck needs. What brand or type of power steering fluid can I use? Synthetic? Availability?
Sorry for the newb questions :)
Thanks in advance!
  • Replies 19
  • Views 5.3k
I though you could pack/replace the bearings on the 2wd trucks?? Maybe I am wrong there. As for the P/S fluid, some people use ATF+4. I think it calls for actual powersteering fluid though. Most universal power steering fluids will work. I am going to start running the Amsoil P/S fluid next week. It meets chrysler's specs. I dont remember what the exact spec number is though...
Me and another guy took  turkey basters and sucked out the old PS fluid several times after runs till it was changed over, nice and clear. We both used the Valvoline synthetic ps fluid and noticed smoother operation and the squeal at start up in cold temps was gone as well.
I know there was one report of a leak using ATF. When he changed over to actual PS fluid leak went away.
I use Supertech Power steering fluid and usually purge the system out by unhooking a return line and routing to a waste bucket. This way you flush both the steering box and the hydro-booster with fresh fluid instead of turkey baster method which doesn't flush the system out too well of debris. ATF is not suppose to be used in our systems. But 2003 and up was ATF IIRC.
Howling noise might be wheel bearings failing and would cause the ABS issues as well. The wheel bearing will lean over a bit and the tone wheel will be out of line with the ABS speed sensors. If you replace ABS sensors you MUST do them in pairs!
as for Ram 3500- it is not a re-pack the bearings. it is big wheel bearing assembly that put on... I think it is 41mm socket and need big torque wrench to set it up.
Ram 2500 are different as use common wheel bearings that do re-pack or replace it it is not look good or rough.
I guess the supertech PS fluid meets Chrysler's specs?
Also it makes sense on the wheel bearing, but what is bothering me is how to locate the actual assembly and the best price. I found a few but they were $230+ for one assembly.
Ah geez that's not what I was wanting to hear but it is what it is I suppose. Torque specs by any chance? Or can I use the elbow torque method?
I would buy a good name brand hub like Timken or such. They have some cheaper units out there that do not hold up very well under these heavy front ends.
Also on the power steering fluid Chrysler still does rerecommend Power Steering Fluid for the 94-02 trucks.
TSB 19-005-03
Power Steering Fluid Usage
Visit Geno's Garage
for Truck accessories.
Date: Aug. 29, 2003
Models: 1994 - 2002 (BR/BE) Ram Pickup, 2002 - 2004 (DR) Ram Pickup
1993 - 2003 (AB) Ram Van
1994 - 2004 (AN) Dakota
2004            (CS) Pacifica
1998 - 2004 (DN) Durango
1996 - 2000 (GS) Chrysler Voyager (nternational Markets)
1995 - 2000 (JA) Cirrus/Stratus/Breeze
2001 - 2004 (JR) Sebring Sedan, Stratus Sedan, Sebring Convertible
1996 - 2000 (JX) Sebring Convertible
2002 - 2004 (KJ) Liberty
2002 - 2004 (KJ) Cherokee (International Markets)
1993 - 2004 (LH) Concorde/Intrepid/Vision/LHS/New Yorker/300M
1996 - 2000 (NS) Town & Country/Voyager/Caravan
2002            (PG) Chrysler PT Cruiser (International Markets)
1995 - 2004 (PL) Neon
1997 - 2003 (PR) Prowler
2002 - 2004 (PT) Chrysler PT Cruiser
2001 - 2004 (RG) Chrysler Voyager (International Markets)
2001 - 2004 (RS) Town & Country/Caravan/Voyager
1993 - 2002 (SR) Viper/Viper Coupe
2001 - 2004 (ST) Sebring Coupe/Stratus Coupe
1997 - 2004 (TJ) Wrangler
2003 - 2004 (VA) Sprinter
1999 - 2004 (WG) Grand Cherokee (International Markets)
1999 - 2004 (WJ) Grand Cherokee
2003 - 2004 (ZB) Viper
2004            (ZH) Crossfire
Discussion:
The factory fill power steering fluid for most 2004 model year Chrysler Group vehicles is ATF+4 (MS9602) and it provides superior performance at both low and high temperatures. WJ/WG and ZH vehicles use unique power steering fluids. Refer to the table to identify factory fill and the approved service power steering fluid by year and model. Note that MS9602 is Red in color and MS5931 and MS9933 are Amber/Yellow in color. All three fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
The part numbers for MS9602 are 05013457AA (quart) and 05013458AA (gallon). The part number for MS5931 is 04883077 (quart). The part number for MB345 is 05127381AA.
MS9602 should not be mixed or used as a “topping off” fluid on systems requiring MS5931. On some past models, MS9602 should be used as the replacement fluid. On these models, if a power steering system is being serviced that results in a large fluid loss, such as a pump, hose or gear/rack replacement, the complete system should be drained and filled with MS9602.
NOTE: This bulletin supersedes owner’s and service manuals for the vehicles listed above that may state to use MS9933 in the power steering system, and that may state not to use automatic transmission fluid in the power steering system.
BODY YEAR FACTORY FILL
POWER STEERING FLUID APPROVED SERVICE
AB 1993 - 2003 MS5931 MS5931
AN 1994 - 2001
2002 - 2004 MS5931
MS9602 MS5931
MS9602
BR/BE 1994 - 2002 MS5931 MS5931
CS 2004 MS9602 MS9602
DN 1998-1999
2000 - 2001
2002 - 2003
  MS5931
MS5931 (built before June 1, 2001)
MS9602 (built June 1, 2001 or later)
MS9602 MS5931
MS5931
MS9602
MS9602
DR 2002 - 2004 MS9602 MS9602
GS 1996 - 2000 MS5931
MS5931
JA 1995 - 1998
1999 - 2000 MS5931
MS9933 MS5931
MS9602
JR 2001
2002 - 2004 MS9933
MS9602 MS9602
MS9602
JX 1996 - 1998
1999 - 2000 MS5931
MS9933 MS5931
MS9602
KJ 2002 - 2004 MS9602 MS9602
LH 1993 - 1997
1998 - 2001
2002 - 2004 MS5931
MS9933
MS9602 MS5931
MS9602
MS9602
NS 1996 - 2000 MS5931 MS5931
PG 2002 MS9602 MS9602
PL 1995 - 1998
1999 - 2000
2001
2002 - 2004
  MS5931
MS9933
MS9933 (built before June 5, 2001)
MS9602 (built June 5, 2001 or later)
MS9602 MS5931
MS9602
MS9602
MS9602
MS9602
PR 1997
1999
2000 - 2003 MS5931
MS9933
MS5931 MS5931
MS9602
MS5931
PT 2001
2002 - 2004 MS9933
MS9602 MS9602
MS9602
RG 2001
2002 - 2004 MS5931 (built before July 2, 2001)
MS9602 (built July 2, 2001 or later)
MS9602 MS5931
MS9602
MS9602
RS 2001
2002 - 2004 MS5931 (built @ Windsor before May 22, 2001)
MS9602 (built @ Windsor May 22, 2001 or later)
MS5931 (built @ St. Louis before June 4, 2001)
MS9602 (built @ St. Louis June 4, 2001 or later)
MS9602 MS5931
MS9602
MS5931
MS9602
MS9602
SR 1992 - 1998
1999 - 2000
2001 - 2003 MS5931
MS9933
MS5931 MS5931
MS9602
MS5931
ST 2001 - 2004 MMC MS9602
TJ 1997 - 2002
2003 - 2004 MS5931
MS9602 MS5931
MS9602
VA 2003 - 2004 MB341 MS9602
WG 1999 - 2004 MS5931 MS5931
WJ 1999 - 2004 MS5931 MS5931
ZB 2003 - 2004 MS9602 MS9602
ZH 2004 MB345 MB345
Policy:  Information Only.
I would like to thank Bob Bergevin, Arthur Cantrall, Barry Drodge, David Lovell, Bill Maurits, and Steve for supplying the information for these bulletins. And a big thank you goes to Geno's Garage for making DodgeRam.info possible.
  Top of Page
  DodgeRam.info Home
This page was edited on: May 3, 2004
I replaced both front hub assemblies on my 01 and ordered the complete kits straight from Mopar for around $300 a piece.  The bearings that Mopar used in the kits that I recieved were Timken sets made in the USA.  I have no idea on the tourque values, but I used the same theory we always use on heavy haul low-boy hubs after new bearings which is tighten up snug to ensure that the assembly is firmly set into the races then back off on the nut until you get a slight stop of the wheel from a good hand turn.  This may be completely wrong but I have not had any issues with the new bearings yet and I have roughly 25,000 miles on them so far, nor do we have any issues on the trailer hubs we rebuild that carry heavy loads for a living.  Just my two cents.
Is your truck a 2wheel drive or 4 wheel drive?
4wheel drive torque specs are 180 ft lbs. I am not for sure on the 2 wheel drive front end.
2wd
Probably not something anyone wants to do but in a pinch it seems to work... When putting the Lincoln back together after the timing cover replacement and reinstalling the power steering pump it howled like crazy (assuming because the pulley was such a s.o.b. to get off, it even broke the puller tool :mad: ). Anyway, since I figured I would be buying a new PS pump anyway I gave it a try :whistle: ...So I added  just a little bit of Lucas and low and behold it stopped the howling and jerkiness on the wheel :thumb1:  It seemed to cure the problem, then the head gasket blew :cry:  :cry:  The heads will come first and eventually I will replace the PS pump, but, in the meantime it will have to do... :ashamed:
Edited by YabbaDoo
2wd heavy duty wheel bearings nuts are torque specific at 280 ft lbs.  good thing I has 3/4dr snap on torque wrench to do that. also the spindle nuts are not re-use!!!!! get new one nut....
Edited by Deafautotech
280ft lbs???
I'll look in the service manual but getting new spindle nuts arrant uncommon. Almost all ford trucks are like that
  • 2 months later...
I thought there had to be something a lil beefier in a 3500 than a 2500. I'm not ready for that job. That front hub assembly was like a hundred pounds, at least that what it felt like when doing the Moog Problem Solver all 4 ball joint replacement a few years back. Truck is a tank!
Just replaced all 4 Ball joints a couple of weeks ago and yes, the hub assembly I estimated at around 85-100#'s!!! It weighed more than 1 bag and felt more like 2 bags of horse feed!! (maybe a bit more :ashamed: )
It's just difficult to hold it up w one hand. & get a bolt started w the other. It was even tough w 2 guys trying to do it. Two bags of horse feed or not!
Did you not use a jack to hold/lift it up in place while screwing the bottom nut on??? :ashamed: That is how this Gal got it done :thumb1:
It was sort of flopping around, as a musician, I need my fingers intact! Rather would have a helper in an unsafe situation.
