- Replies 63
- Views 122.9k
Mailboxperry 29 posts
mopartechnician 11 posts
MnTom 10 posts
Ilikeoldfords 3 posts
Tested on 2000 Dodge Durango PCM, 20 ohms - full <-> 240 ohms - empty @ 10 to 0 Ohms, short-circuit @ 0.40v to 0.00v @ 20 ohm full
I just bought a 2002 dodge 2500 cummins quad cab. The fuel gauge was not working. It was stuck below E with fuel light on. Took it to local shop and they said need new sender. Looked on here and found the correct part number. Thank you. Shop installed and gauge still not working. Shop tested wires and said they are sending signal all the way to the PCM. After that they don't know. I looked on here how to test cluster with the trip button. The gauge moved as it should. I brought truck home and need to know where to look next. Thank you.
