- Replies 26
- Views 33.2k
Mopar1973Man 9 posts
Tim Waldo 8 posts
dobienut 5 posts
CTcummins24V 2 posts
Some history..laid my truck up for winter, got it out and did a oil change and fuel filter change before I started driving it. Drained the fuel bowl so I bumped the starter about 5-6 times to allow it to fill before I started it, still ran dry of fuel. Cracked injectors and got it running but was stumbling a bit from air. Lasted about 1/2 hr before it cleared but also caused engine light on with 1690 code. Finally cleared up and light out, but the truck still has a different sound then i'm used to, more of a pingy sound and once in a while it seems to stumble when taking off.
Today about a month since the first case, I started it and engine light came on and stumbling alot @ idle, clears itself at about 1200 rpms and work fine, good power. Called my local Cummins dealer and talked to the guy I go to, he said from his info he'd point to the crankshaft sensor first if he had it there as its the cheapest and easiest place to start. I put a new sensor in and started it up, still runs like crap. So next it checking for wire chafes I guess and wondering if anyone experienced the same thing and where they found the problem. May help me cut some time and searching down
Have video but cant upload it here
