How many holes are in the stock injectors? I thought the stock ones had 5 and  I just got some BD 40hp injectors part #1040275  and they only have 4 holes in the nozzle :think:  I was under the impression that it would have more holes for better atomization... As I was looking online to see if I could find any specs on the BD injectors I stumbled upon  some injectors on Diesel Power Products... http://www.dieselpowerproducts.com/p-7530-dodge-12-valve-fuel-injectors-9070-hp.aspx more power then the ones I bought and 1/2 the price... Has any one used DPP injectors and if so what where the results?
  • Replies 48
  • Views 13.6k
They should be 5 hole injectors for the 12v, I believe what BD calls a +40hp injectors for the auto trucks is a 5x0.010 injector (same as the stock injector in a 215hp 12v)
When I make the upgrade to bigger injectors I'm planing on getting them from DAP since I know they build good injectors, and they sell them for a reasonable price $355(plus core) for a set of 5x0.012 injectors (+90hp)
Edited by bjytech
I have never heard of a four hole injector.........
Just got off the phone with BD and they are 60hp SAC nozzles. He said they produce a ton of smoke soooooo, I will be returning those and getting the 40hp VOC...
Far as I know there are not any readily available 6 or 7 hole injectors without them being custom made. HOWEVER, I did find a set of 10 hole injectors but they are for extreme racing or pulling only.
I know of a place that makes 7 hole 12v injectors but they are made for high horse and racing/pulling applications.
Thank you, but I don't want to smoke all the time :cool:  Otherwise, I would have kept the 60hp's :thumb1:  They went back today and a set of 40's are on the way!! :thumb1:
That is why I bought a 97 :thumb1:  Most of the time there is a method to my madness!!! (most of the time...
 not all of the time .. :cookoo: heheehe)
Edited by YabbaDoo
Hey MnTom is there a 6 or 7 hole injector for the 12V??? It would do YabbaDoo better I would think with a nice wide spray pattern.
Not sure if it's true, but I read that you should use 5 or 6 hole injectors for 12 valves, and 6, 7, or 8 hole in the 24V, just because the cup in the piston is different??
Like I said, not sure if that's true or not. Maybe someone can explain.
It's not the number of holes, but rather the spray angle. The 12 valve injectors are at an angle to the piston and the 24 valve injector is right above the piston. HOWEVER, no matter how many holes or lack there of, if the injector is not spraying into the bowl in the piston you will melt the piston and probably have an EGT and smoke problem too.
Ok, the good news is the replacement injectors got here today :thumb1:  But, the bad news is they sent the same 60 hp SAC injectors they sent before :(  :cookoo:   They said they would be sending the original 40hp VCO nozzles and a hoodie for my troubles... Yeah, 60hp smoky SAC nozzles vs the 40hp VCO clean burning... Or at least so I hear :ashamed:  Should I keep the 4 hole 60hp SAC injectors??? And if so why? The guy at BD is the one who said they would smoke all the time :(  I do not like any of my vehicles to smoke and would like to have clean burning power with better MPG's. All opinions welcome :)  Please :thumb1:
Edited by YabbaDoo
The only 4 hole injector I know of for the 12v is a marine injector so I don't think it would have the correct spray pattern to get a good clean burn in your truck. As for SAC or VCO they say VCO injectors run a bit cleaner than SAC but I don't know if it's really that big of a difference or not.
The VCO's are the ones I wanted... But 2x they have sent me the 4 hole 60hp. I wanted to get the new Injectors installed over a week ago, but they have now screwed up 2x :doh:  :doh:
Sounds like its time for a refund and go somewhere else where they will do it right the first time.
I would however, a friend bought them for me on his Summitracing card so that I could just make payments vs having to lay out all the cash at once... Remember I just had the heads done on the Lincoln and 6 brand spanky new shoes for Yabba :thumb1:  So, 6mo interest free makes it the only choice right now :ashamed:
Ahhhhh, I see! Well, good ol' patients just reared its head... Interested to see how the 40's will do for you.
paypal/bill me later does that. Most vendors accept it, and if you spend over $100, you get 6 months interest free to pay it off. Works out really well. DAP has it, Rock Auto and just about everyone else.
