CAI in Summer VS Warm Air in Winter
- Replies 24
- Views 6.2k
Mopar1973Man 9 posts
AH64ID 4 posts
flagmanruss 3 posts
guesswho512 3 posts
I'm sure everyone here knows what a CAI (Cold Air Intake) is... designed to draw cooler outside air into the engine instead of warm / hot underhood air. This is argueably desireable in summer when the under hood temp climbs outta sight. These thoughts carry over from our experience with gassers and I'm not at all sure they directly apply to a compression fired engine (diesel)... especially a turbo-charged intercooled diesel. Any rate the OEM air box is plumbed into the fender which draws cold air from behind the headlight... Atmittedly not a huge passageway but a CAI. Just a general reminder, that diesels "fire" from the heat of compression. A turbo adds temperature when it boosts the charge pressure but then in goes through the intercooler... before reaching the intake manifold. NOW I want to flip flop the scenerio... in winter the ouside air will be well below the most economical point. The IAT sensor will adjust the fuel to run righer in order to make it run. The cold fronts so many of us use block some or all of the grill raising the under hood temps above ambient. Those who are running BHAFs are already drawing engine room air... despite any heat shielding panels that may be in place. So this may be benificial in drawing the warmest winter air available. I'm still running the stock air box plumbed into the fender. Even with the cold front in place I suspect the air drawn in behind the headlight is still colder than underhood air. So my theory is that it would be better to disconnect the snorkle into the fender & block that opening in winter. Maybe even do the swiss cheese mod to the airbox. Your thoughts?
