- Replies 35
- Views 47.7k
dave110 15 posts
mopartechnician 7 posts
Mopar1973Man 5 posts
mulcher812 3 posts
Hello all! I have developed a hard start/ long crank after the truck sits for awhile, even if just over night. I thought the bat's where bad so I had them checked and they were good. They guy at the local shop that does just starters and alternators has a 2nd gen. Cummins and thought it cranked a little slow so I put in a rebuilt starter.( I took it apart when I got home just to see and they did put in oversized contacts like the ones from Larry B's
). WOW! It cranks almost twice as fast now. Thought I solved my problem but the next morning it still cranked for 3-5 seconds til it started. Used to be it would roll over 1 time and light off and it is still that way when it is warm but let it sit a few hours and it cranks long. So I have decided I am losing fuel prime. Watching closer today I got a puff of white smoke at startup. I parked nose down but no change. I bumped the starter and let the LP run to try to purge the air out but no help. In researching I found some good suggestions but also have some ?? now. Some say the stock filter housing but that is already a high spot. How would air get from there down to the VP and up to the head? I'm assuming the return line in back of the head or the "T" fitting behind the stock LP but I have not even the smell of a fuel leak. If air is getting in, fuel should be getting out. If air is getting in it is displacing fuel that has to be going somewhere. Correct me if I'm wrong. I'm just trying to understand how this works to make it easier to diagnose.
Oh, I almost forgot. It seems the banjo washers and grommets for the return line must come from Cummins. I don't have a dealer close by. Do they have a website with a parts breakdown with part #'s or does anyone know the part #'s? Anything I am missing?
Thanks!
