5.9 vs 6.7 exhaust manifold
So in order to complete my conversion kit for my he351ve swap, I'm having trouble deciding which exhaust manifold to use. I'm trying to figure out whether or not I will see anything negative with running the 6.7 manifold than the 5.9l. Flow restrictions, etc. Sound is not a huge deal since its all going to change anyways.
I don't want to keep mulcher hanging by a string, lol.
  • Replies 10
  • Views 7.6k
I'm sorry I can't even give you advise on this topic at all. I have no knowledge with HE351VE nor the 3rd or 4th gen exhaust manifolds. I know there are people that do them... Hopefully there is someone that can help you.
Yea, I was hoping maybe some of those guys could chime in on the performance or lack of it about the manifolds. I know there is emissions stuff for them, but dunno if even after being blocked off if they do okay or if the manifold is still poorly designed for what I have in mind...
Texas, I've reviewed that thread a few times. I have not read all the pages because its 80 pages long, but it seems like he reuses the 24v manifold and does not even have to alter the he351 mounting? In his pictures, you don't see anything special done to it, just bolted straight up and no adapter or anything!
Post #124 in that thread says it bolts directly onto a stock T3 manifold.
The VE will not bolt directly to the 2nd gen manifold without machine work. There is an Ebay adapter that will allow fitting, but in 4WD models you will have shock bolt issues.
3rd gen manifolds will work & provide enough for 450-500 HP on a Common rail 6.7, so I doubt you will have backpressure issues. Get the downpipe for it if going this route & oil feed & return lines will have to be modded or replaced.
The sound is from the turbo, not the manifold.
Ed
Yankneck nailed it, the VE flange is different that a T3 flange.
The biggest difference is where the turbo sits, but some get it to fit with just the adapter.
You may also ask a company like steedspeed if they will make you a manifold with the WGMT flange in the 2nd gen location.
I spoke to all of the manifold manufacturers & none are willing to do a center dump manifold for the HE351VE. It's either the 08+ manifold or the adapter.
Ed
Interesting, you would think it would be easy for a welded manifold like the Steed.
Thanks, Ed.
I'm going to try and make this swap as painless as possible as I know the more I try and simplify it the more I could complicate it.
