Update on my 47re mod
- Replies 10
- Views 3.7k
diesel4life 2 posts
Yankneck696 2 posts
oldbeek 2 posts
Ed ke6bnl 1 post
Put my 2001, 47re with 2nd gear lock up to the test this past weekend. My rig with 5r weighs 17,600 lb. I navigated parts of the 6% Grapevine canyon on I-5. The trans worked flawlessly. On grades I would lock into 2nd push her up to 2000 rpm and flip the torque converter lockup switch. The oil would heat to 210f while pushing up to 2000rpm. After lockup trans oil cooled to 180, eng temp, and stay there. The grade and load took all the 235hp at 2700rpm I had with skinny pedal flat on the floor. Going down same grades decelerating, I had the same result. Just love that mod. Strongly endorse the 2nd gear lock up mod.-
