- Replies 14
- Views 6.6k
Me78569 6 posts
MnTom 2 posts
mopartechnician 2 posts
TFaoro 1 post
For some time now I have not been able to switch the Transfer case into N and therefore no 4l either. I have 2wd and 4h.
This happened due to my dumbness. Last year when I swapped my tranny I caused this. I had the truck up on jack stands and the truck was idling and I was going between P R N D to make sure the tranny was working. Now I made the mistake of testing the transfer case with the wheels off the ground so even in P the rear wheels were moving slowly.
once I kicked it out of N iin the transfer case It grinded but finally went into 4l. I then tried to go back to N in the Tcase and it grinded again and when into N.
After that I put the rear of the truck back down and it shifted into 2wd and 4 high fine, but no longer into n or 4 low.
My question is how badly did I screw the transfer case up? It is possible for the tcase to "out of sync" and therefore not sync?
Think it is possible to R&R the case or should I start looking for a new one at some point?
nick
