Dealer says high idle won't work because of remote starter/alarm
I took my 2002 HO cummins with the 6 speed manual transmission to the dealer the to have the 3 and 6 cylinder high idle enabled . They said it was to warm to try it but said it was enabled . I've had a chance to test it in -18C, or 0F. Nothing happened after 10 minutes. I called them and they said my remote starter and alarm probably isn't letting it work. Has anyone else ran into this or heard this?
  • Replies 31
  • Views 4.9k
  • snowshoveler
    snowshoveler
    With my DRB 3 scan tool you just go in to owner preferences ( I think thats what it says) and there is a heading to enable high idle. You just click the yes arrow and its done. I should be doing thi
  • We should start a collection of the lame excuses from the Stealerships.   Ed
  • mopartechnician
    mopartechnician
    I keep telling people its super simple to enable it and that you dont flash the computer but nobody believes me
Yeah my neighbor came over and knocked on the door to tell me there was something wrong with my truck. He was afraid it was going to throw a rod or blow up...
The wifes ford is acting up so she has been "borrowing" my truck even though she hates Dodges.
She started it this morning, was about 20 degrees and it went to high idle on its own.
She remarked that it was cold for it to do that. I said no we don't have any idea about cold.
Folks here know all about 30 and 40 below...brrrrrrr.
Regards Chris
I should be doing this for people ...bring me a coffee.
Only takes about 2 minutes and I am not "good" at it yet.
Regards Chris
I'll bring donuts as well if you want to do mine. I'm in Ohio.
Well....
I am in Nova Scotia.
I think your truck will be warm by the time you get here and the coffee will be cold...the donuts , I have no idea how they will do.
I should have just sent the DRB tool to Mike or Ed and let them help folks as they could do this easier than me.
I don't think there are many members here in my area.
Regards Chris
Well....
Regards Chris
Oh well I keep trying to find someone near Columbus Oh to do mine no luck so far. As for the donunts I'll have wife vac seal them, that way they'll be fresh maybe a little smashed.
Ya the stealership flat told me it wont work on the manuals too. I even printed out and brought in the TSB paperwork and he laughed at me and said he doesn't know what moron wrote that up. Same guy tried telling me that the PCM and ECM on these trucks is the same unit!!!
Doesn't that just makes you want turn his light off, I get pist when have to deal with retards that think they know everything.
  • 3 weeks later...
I noticed now whenever I don't plug the truck in when it's at 0*C or just below it will barely start . And when it did go once it sounded like it was in 3 cylinder while running for the first 10-15 seconds. Anyone else notice this after having the high idle cold start enabled?
It used to start easier at -20*C before when not plugged in.
That sounds a lot like the grid heaters are not functioning.
